High pitch whine at 60 MPH after 5.38 re-gear
Have same whining sound. Definitely from the roof rack mount just above the winshield.
Happens right between about 58-61 mph. Goes away if I add or subtract an mph.
Sounds like a bad gear set up perhaps made worse if they filled the diffs with a synthetic gear lube. It's especially important to run a conventional gear lube during the critical breakin to help the gears run as cool as possible.
I confirmed that they install/used conventional gear lube before and after the regear. No worries there.
Reactions: Jerry Bransford
