Wow - what an impressive project.
I am also doing the Kicker COMP RT 6.75 update in the OEM center console sub enclosure. I've got everything disassembled, trimmed away the plastic behind the sub, so there's no clearance issues there.
What I discovered this morning - and I've not seen addressed anywhere I've looked - is that the basket of the driver hits the wall of the OEM enclosure at the top, directly under where the cassette cubby sits. I'm going to either have to cut that part of the enclosure away and rebuild the wall, or use a spacer around the driver to bring it out a bit - and risk the front of the driver hitting the center console cover.
Did you run into this? If so, what approach did you take? I assume the OEM enclosure has not changed between years. My TJ is an 02 and the OEM enclosure has 56038609AD / 36690 / 7136 on it as a part number.
