Another update from November 2022:
Custom intake is completed!
Parts list:
- Spectre Performance elbow (SPE-9785)
- Spectre Performance intake with MAF sensor pad (SPE-9718)
- Spectre Performance 4" Flex Boot (SPE-9775)
- 3/4" Hose Through Hull Fitting (https://www.ebay.com/itm/1226411545...pid=5337789113&customid=&toolid=10001&mkevt=1)
- Vibrant Performance 0.750" I.D Silicone Vacuum Hose (2108)
- GM Performance filter (19302206)
- Outerwears 6" bottom diameter, 5-1/4 top diameter, and 9" tall (part # 20-1185-01).
The secret sauce is using a through hull fitting from a boat discharge port. I placed it between the MAF sensor and throttle body.
I then used a silicone hose to hook it up to the valve cover.
I'm not in love with the open air filter element and plan to remake it in a box with an OEM filter when I have more time. In the meantime, I put on a Outerwears water repellent prefilter and will be avoiding risky water crossings.
Great work, Tox. Are those Duetsch connectors?
And remind me - which LS do you have in there?
It's a 6.2L LS3 paired to a 6L80E transmission.
Awesome. That's such a cute little mill...
toximus - What kind or make radiator did you use?
Thanks!
Post 721 is Metri-Pack and APEX 2.8 connectors. 738 has one Duetsch connector pictured that I'm using for turn signal lights. Duetsch is my connector of choice for any work I'm doing.
As the owner of a 6.2 and 6L80E in another application, did you go to a billet or some other aftermarket converter? These are know to crap out 80k-150k miles and grenade the entire transmission with it. I have yet to read to the point of what you used (new, takeout, etc).
Also I know I don’t know anyone here but Oshkosh airshow… put me down for one (besides that inconvenient roughly 3 week old at that time)
From the battery I'm running a breaker which then powers those interior fuse blocks. This completely separates all of my "aftermarket" stuff (aside from the winch) from the essential wiring. So if I ever have a problem, I can just turn it all off with one switch.
Your wiring looks good! FYI, I have had problems with those types of breakers under the hood in my stock 4.0, too much heat! One failed outright and the acted wonky and took a while to diagnose.
What brand did you use?
First one came from eBay second one was Blue Sea. Mine were thermal based. Switched to ANL fuses.
