tbreaux
Ok thank you for the reply.I think the gap is enough, but if it isn't it'll self clearance some if it makes contact — worst case I'll have to add a bigger spacer at the belly skid to increase the gap. The reason for making it out of heat treated aluminum and allowing it to flex by only supporting the font and rear is so that the skid will flex and return back to it's original shape and not permanently deform which would cause the skid to be pressed against the vibrating engine and wear a hole through the pans.
