So I recently swapped my front and rear axles for a set from a LJ (for the dana 44 and higher gears). I also removed a spartan locker I had in my old dana 30 and reinstalled it into my new axle. Took the jeep out wheeling and anytime going over larger bumps I would get a horrible grinding/popping noise coming from the front. Noise was present in 2wd and 4wd. Locker also seemed to work just as normal. Have some small metal flakes in the diff after pulling the cover but everything visually looks okay. what is the normal amount a metal material for a diff? Any ideas on what could be causing this noise before I start pulling the carrier?
Thanks.
Thanks.
