Dropping the pan only allows you to drain/replace about 1/3 of the ATF inside the transmission, it doesn't drain all of the ATF inside the transmission, its torque converter, and its cooling system. I'd drop the pan to replace the filter, then add 4-5 quarts to of fresh ATF+4 to top it off, then flush the old ATF out into a bucket until it turns clear bright red.
Flushing is done by disconnecting the transmission cooler output line connector from the radiator and (while the engine is running) using the transmission pump to pump the old ATF out into a 5 gallon bucket while you add fresh ATF+4 (only!!!) from the top via the transmission's dipstick tube after inserting a small funnel into it. Stop flushing once the ATF turns bright/clear red. Then once the cooler line is reconnected to the radiator, top off the transmission with enough ATF+4 to get it to the full mark. Only measure the ATF+4 level with the transmission dipstick while the engine is running so you can get an accurate ATF level.
so you have this same Trans I presume, but is this going to affect anything with my completely flushing the system with how many miles it has because I don’t want to attempt this and it starts to slip. The reason I want to change my fluid is because the transmission acts a little werid when driving. I’m not sure if it’s just me or the tranny is actually acting up but when I’m driving it’s like it’s has werid shifts sometimes but the fluid looks just fine but I’m concerned and I want to change the fluid and filter as preventative maintenance and the fact that I’m a little paranoid. My dad drives it and he says he doesn’t notice anything but I drive it every day and I feel like it’s slips sometimes or something of that nature. I have 17 inch jk wheels on it but they are stock tires not much tread so it shouldn’t be putting that much load on it.
