I just finished replacing 6/8 of my control arms and I tried to match my old angle as best as I can. Does it look okay? It’s the stock rear driveshaft with a 2.5 inch lift
Agree.It's pretty difficult to just eyeball it and say if it looks right or not.
You could measure the pinion and tranny shaft angles (should be the same with that type of driveshaft).
Does it have driveline vibes at 70 MPH? If not, it's probably fine.
Vibrations start around 70-75 and before I changed the control arms they started around 80. The only issue is the upper control arms are now bottomed out so I have ran out of adjustability.
If you're getting up to 70 before the vibes start, it's pretty close to correct. You might want to adjust the pinion back a little. Sometimes going the opposite direction of what you think it needs actually hits the sweet spot. Do you feel lucky?
Why can't you tweak it with your LCAs?
I don’t wanna adjust the lcas because they are now equal to the front Lcas and I don’t want to shorten my wheel base. When you say adjust my pinion angle back, do you mean lower the differential down or raise it up?
