Did you guys use any spray adhesive to keep the carpet down? I'm using ACC thick pile carpet. And I'm sure it's going to need to be trimmed along the top lines of the carpet. And probably fit loosely on top of the sound deadener and the heat shield padding I am going to use. (Probably same thickness as your 170mm layer.)
I was wondering if one of the 3m spray adhesives was strong enough to keep the carpet down. But light enough that you could pull the carpet up if need be. Like a halfway shitty adhesive?
Your carpet is probably not sliding around due to the use of 170mm rubbery surfaces layer. Mine is like a foil over insulation type stuff. Like that foil insulation at HD. But better. I'm assuming my carpet is going to slide around on it a bit. Floor mats will probably help keep it in place. But was considering using a 3m adhesive between the carpet and the foil layer.
IDK. Maybe if I just spray it lightly and only in small places to tack it down. It might come up easier if I ever have to pull the carpet up. I don't know which 3m is the easiest to pull up. Maybe the General Purpose one?
