I have a 2003 TJ with a 4.0 that I have been fighting an exhaust leak on for 6000 miles. The muffler was shot so I replaced it with a Flowmaster cat back. It is leaking around the collector at the manifold. I have taken the exhaust completely off and cleaned it with a wire wheel and bought new bolt and c-nuts and put it back together and still no good. I even pulled it back off and put a bead of copper high heat silicone around the inside of the collector and it was good for a couple of weeks and then started leaking again. The cats are not factory, they had a 2017 on the heat shield on them and looked really good when I looked down in them. I am open to suggestions at this point. I did the whole shop vac in the back of the exhaust and squirted soapy water on it and is for sure leaking at those collectors. I know those are supposed to just be metal on metal but do they make some sort of collector gasket I could make work to seal it up. You can see in that top pic it doesn't even look like the header is making contact hardly anywhere on the collector.
