My current setup has a 1 gallon tank mounted to stock shovel. I've seen some mounted horizontally back by fuel tank but doubt they'll fit w/out interference post tuck. I need to find a solution soon! TIA.
It would seem that the basics of compressors and compressor storage tanks escape most. Any tank in a Jeep for the storage of compressed air in a size that does not overwhelm the efficacy of the rig is wholly useless with one very minor exception. If you run a York OBA set up and need an oil separation unit, a small tank works for that a bit. Everything else is silly and a waste of time, money, and space.There is the fundamental question of why is the tank needed in the first place. I haven't missed mine since removing it last summer.
I think it depends on the application. I have to have a tank for my AiRock system so I'll be trying to figure out where to remount mine. Might have to put it inside the body if I can't figure out a spot under the rig.
Keep in mind that the entire plumbing system after the check valve on the pump head is an air tank.
Not hard to figure out. With the system at full shut off pressure, start airing up a tire. How long from the time you start until the compressor kicks on? That is what the tank is buying you and it is never much and never enough to justify the installation of a tank. What everyone misses is once the compressor kicks on, you are no longer working on anything to do with the tank, you are running straight off of the compressor so all the tank, its plumbing and crap gets you is that brief few seconds of compressed air before the compressor kicked on.What would you consider large enough to make a difference? Are we talking 5 gallon or larger?
Yes. I remember people using their bumpers and roll cage as a tank.
ORO has a new redesigned York that is suppose to be oil free. But it isn't cheap either.
https://offroadonly.com/shop/on-boa...york-compressor-with-finned-head-tj-specific/
Do you need a tank, or do you need a manifold to mount shit to?I think it depends on the application. I have to have a tank for my AiRock system so I'll be trying to figure out where to remount mine. Might have to put it inside the body if I can't figure out a spot under the rig.
I probably did the same conversions to mine to keep the oil in the bottom end. Tap and plug one hole.
Back to yours and the AiRock, how often were you able to actuate the suspension without activating the pump?
My all time favorite air compressor has a tank smaller than a coffee cup on it.i'm still kickin the idea of resourcing the A/C compressor. but i have more more chit to do 1st.
my compressor goes down and my front locker is dead weight unless i put the manual full time lock in. a small bottle for an emergency situation is similar to a spare u joint or engine belt or tire patch kit....................i don't expect to have to need or use it but as soon i don't have it. that's the bastard that'll go down 1st. it's under 2# while it wouldn't carry the pressure CO2 would, it's enough to cycle the locker a few times.
i'm not lookin to fill wheels or run an impact gun in the field.
