P0344 I believe.
I don't know what a P0344 on the TJ is. If it was P0340, I would agree that it's not likely a sync issue. That one means the PCM hasn't detected a pulse on the cam sensor signal for 5 seconds, so yes, the TJ will barely run, if at all.
The P0344 code indicates that there’s an issue with the signal coming from the Bank 1 camshaft position sensor.
P0344 is usually caused by an intermittent electrical fault. That fault is usually caused by an issue coming from your Wrangler’s camshaft position sensor, or the sensor itself.
I think you can pull your upstream O2 sensors to try and diagnose a plugged cat. If performance improves with the O2 out, that's a good indication that your cat is plugged.
well pulled the o2 sensors and it ran better. so time to order cats. but while driving it up the street with sensors out it melted the line for the clutch master cylinder ! DAMNIT![]()
well ordered flowmaster cat kit with all 3 cats and clutch master cylinder kit $485 I guess it could of been worse. now hopefully that fixes it![]()
I ordered the flowmaster cat kit from Holley as recommended on a thread here. Should get it Thursday. I may wait until fall and take jeep home to Texas . My son has a mechanic that comes to his property and does work on his stuff. I would feel better having his help. I'm 78 and still do some mechanic work, but just afraid to tackle this. Jeep runs OK, just tired of check engine lights. Hopefully you will update this tread when you change cats.
the clutch master cyl. hasn't shipped yet so I'll have to wait on
well finally got everything put back together and the PUMKINATOR is back in service![]()
. It was the cats, the honeycomb on the fwd pre cat had came loose, not stopped up as both are clean, the crap just came loose and lodged where it necks down. hopefully tomorrow I can remove the all the melted wire loom and begin to replace it
