Hey everyone,
Some weeks ago, I installed a 2" lift. So, I removed everything without a problem. I had a problem installing the new longer springs, so I used a spring compressor that I'd borrowed from a friend just in case I needed it.
The thing is that I need to do it again, because I decided to change the shocks and set up the bump stops for the new ones. The ones I bought run short.
I will write down the steps that I did, so you can tell me what I am missing:
1) Jack up the TJ
2) Add jack stands at the frame (behind control arm brackets)
3) Remove shocks
4) Unbolt track bar (axle side)
5) Unbolt sway bar end links
6) Droop the axle
The axle couldn't go any lower, and the springs (OLD MAN 932/941) didn't have any chance fitting without a spring compressor.
1) Jack up the TJ
3) Remove shocks
6) Droop the axle
