Intermittent Overheating
TJBart
Tennessee
Hello
I have a 1999 Wrangler with the 4.0L and Automatic Transmission. I have been having an issue with intermittent overheating over the last week. I have had this jeep since Christmas, and when I bought it the thermostat was stuck open and it ran very cool. I replaced the thermostat and it ran fine until I took it 4-wheeling last weekend and it overheated on the interstate on the way home. I figured it might be the thermostat sticking closed so I replaced it again but it has overheated 2 or 3 times over the last week. The car will normally run slightly over 210, but occasionally it shoots up into the red zone for a few minutes. It normally drops back down to 220 or so before I can get off the road to shut it down.
Would air in the coolant system cause symptoms like this? Any other ideas what it could be?
Thanks
Could be a lot of things. Is the radiator oem Mopar, or some store brand aftermarket? It makes a huge difference. I made the mistake of putting in an aftermarket radiator a few years go and it had trouble maintaining 210 in hot weather or beach driving. Finally put in a mopar radiator and it runs at 200 all the time.
Also, replace the radiator cap for good measure.
How is it "overheating"? Is this condition based on the gage only?, or is it
boiling and forcing coolant through the overflow bottle?
A good Stant radiator cap and coolant change is a great place to start.
Welcome to the Forum!!
Occasionally you’ll end up with a bad (new) thermostat. Did you test it before install?
So I think I figured it out. I did a flush and it definitely needed it, and I went ahead and replaced the radiator cap just in case. The thermostat is a new 195F unit so I figured it was good. I also noticed the shroud was loose on one corner and re-attached that. And finally I noticed that the back of the radiator had a bunch of mud on the fins. I hit it with a garden hose and was amazed at how much mud came out of it. I just got back from a long run and it never got above 200F. I am thinking the mud in the radiator was probably the main issue. I washed it after I took it wheeling last weekend but I only sprayed the radiator for a few seconds.
Thanks for all the good advice.
