For those that have used Eastwood Internal Frame Coating to encapsulate the inside of the frame; how many 14 oz cans (covers 10 sqft) to generously coat the entire frame ?
2-3 cans will cover it. I used 4 on my new frame when I first got it but I made sure that it had time to dry and flash off between coats. I also put on a top coat afterwards. I'm not sure I should have but it has not been an issue.For those that have used Eastwood Internal Frame Coating to encapsulate the inside of the frame; how many 14 oz cans (covers 10 sqft) to generously coat the entire frame ?
I used their torque box body mount repair channels last year on the Chili Pepper frame swap. Quality and service was excellent.Very cool! I hadn't heard of those guys before. Their prices are way better!
Pretty much the same here, I used 1 full can on the first coat in each rail with a slow deliberate advance of the nozzle then gave it time before taking a look with the camera, then I used a 1/2 can in each rail on the 2nd coat. The external received 2 solid coats of Eastwood extreme chassis black (love that stuff) I still have the 4th can new on the shelf.2-3 cans will cover it. I used 4 on my new frame when I first got it but I made sure that it had time to dry and flash off between coats. I also put on a top coat afterwards. I'm not sure I should have but it has not been an issue.
When I had my daughter's Jeep done by Auto Rust Technicians (Safe-T-Cap), they cut out all the old cancer, sandblasted, welded in both frame rails with rear control arm brackets, and undercoated for $2,700 including taxes.No way. If you're paying 3k, get it done at Auto Rust Technicians who will install full-length Safe T Caps and sandblast/undercoat for roughly that price.
Interesting perspective. I'm thinking about this from a off road motorcycle perspective. I've been involved in multiple discussions on how to seal the air box from water, and it always comes down to water will always get in, how do you get it out. I've added extra drain hole to my frame, and put rubber plugs into to holes on the side of the frame in front of the rear tires.From my experience (mostly boats, mind you), water will always find a way in, and when it does, you want it to find its way out, or at least be able to notice it and then force it out. I would prefer to know that water has a way in and out, than to hope that water hasn't snuck in with no way out.
