IDK shit but i might opt to feed to the GM harness and ARB isolated from the convenience items, then spit them between lights vs warm buns and music.
was thinkin backwards myself, wouldn't want a convenience function shorting and possibly taking out a more important component. or even just for diagnostic simplification based on sys's isolation.But if the GM harness and ARB stop working, at least I'll have tunes and warm buns.
There's not all that much difference between 1/0 and 2AWG, so realistically, either is fine. 1/0 would give you some headroom in case you ever install a high power alternator. You can actually run a 370 on 1/0, just with a tony amount of additional voltage loss.
That makes sense. Mechman was the maker of the 370a alternator I had in my F150. Like Singer, most of them are based on Denso cores.That seems to line up with what Mechman says too. Although, they skip 2ga. I'm only running about 2ft of cable.
https://www.mechman.com/content/instructional-pdfs/General-alternator-installation-instructions.pdf
240 is a lot... Like more than most of the welders we have in our garages. If your building for that much current, you're oversizing all your main wires, and copper is really expensive.
Wouldn’t the smaller pulley generate more rpm/charging than a stock larger pulley and be harder for the engine to turn? Essentially the same as using the small sprocket on a rear bicycle wheel.The reason for the 240a alternator is 2 part:
- The introduction of the electric fan.
- I'll be running a smaller than stock pulley on it (for a longer life on the high revving LS) on the alternator so I upsized to get more at idle.
You caught my error. Larger, not smaller.Wouldn’t the smaller pulley generate more rpm/charging than a stock larger pulley and be harder for the engine to turn? Essentially the same as using the small sprocket on a rear bicycle wheel.
The amperage draws you gave to be way higher than they really are
And the oversize fan pulley isn't likely to be needed either, amps drawn at idle rpms are seldom all that high.
I'd run with the stock pulley long enough to see that/if it's keeping the battery charged adequately. Alternators put out more amps at idle rpms than the old generators did and not everyone is aware of that. My old VW and its generator would turn its generator light red, which indicates a battery drain, whenever I came to a stop with the headlights on. I'd have to rev the engine to make the red light shut off.
Oh you meant a larger pulley on the alternator, not the drive pulley. That makes sense.Again, the larger pulley is to INCREASE life, which will DECREASE output. Because it will spin SLOWER.
It looks like you are way over complicating things, I also don’t see a reason for the high average alternator, the factory alternator should power everything fine. Most high average alternators take higher rpm to start charging so that would hurt your charging at idle. On engine conversions I wire, I add a high amperage Bosch that is turned on by the factory ignition switch. I would power up the LS system with that relay this takes the load off the factory wiring. Then I would put one fuse block for the aux items ( seats, lights etc) or I would use relays and fuses in the factory pic for these accessories. Your cooling fan should draw 20-30 amps max with maybe a little higher on start up. Heated seats under 5 amps per seat, led lights don’t draw huge amounts of power either.Latest revision.
The highest draws that the PDC runs are the (led) headlights, wipers, interior lights, and radio head unit (touch screen). Removed from stock is the engine ignition, fuel pump, and speakers. Hence the smaller than stock 10ga.
The 1/0 between the engine, firewall, and battery are probably overkill still. The 4ga to the 140a block might be a little overkill too but will prevent electrical quality issues to the GM harness (it'll package nicer than wiring it to the battery).
I'll leave enough wire length on the GM harness to route it back to the battery if needed.
Any ideas for neatly positioning the 5 wires connecting to the positive terminal?
40a ARB #1
40a ARB #2
30a Light bar
40a fan (still waiting to hear back with a final number on this)
15a rock lights
15a back up lights
40a speaker amp
40a subwoofer amp
Speakers and ARB would never be on at the same time.
ARB #1 | 40a fuse | 14.2a draw |
ARB #2 | 40a fuse | 14.2a draw |
Fan | 100a breaker | 40a draw (*not official) |
Light bar | 30a fuse | 20.71a draw |
Rock lights (combined) | 15a fuse | 2.6a draw |
Back up lights (combined) | 15a fuse | 2.1a draw |
Speaker amp | 40a fuse | N/A |
Subwoofer amp | 40a fuse | N/A |
Heated seats (combined) | I forget | 7a draw |
