Been using regular gas , is it ok to try 100 pure gas ? Any inputs ,or unleaded? was going to try 100 pure, thanks
Do you use 100 gas, I'm going to put in tomorrow100 % gas is what the Jeep was intended to run until the ethanol craze came by and now we have to run on corn syrup which ur Jeep is not intended to run which will eventually gum up ur full lines
Only in my boat, mower, dirt bike and suchDo you use 100 gas, I'm going to put in tomorrow
Gum up your fuel lines? Ethanol will clean up your fuel lines. Gasoline leaves deposits. If there is enough build up in the system combined with higher % of ethanol, a gel can clog filters and even injectors. I've never heard of E10 having enough solvent strength to cause gel to form. I switched my old Mustang to E50 and it cleaned the system and deposited it in my carburetor. It ran crappy, but after cleanings of the bowls twice I never had another issue.
My buddy owns a shop and he’s seen several pre ethanol vehicles have deteriorated full lines and such.. I’m no expert just passing on info. Results may very
If you mean ethanol-free fuel...my Jeep runs really well on 93 octane ethanol free fuel... And I've noticed it's somewhat picky.Not sure what you mean thanks , should I try 100 gas?
I have a 2005 Wrangler X , just purchased several months back it has only 35,000 miles
