If it ain’t broke, don’t fix it…
That said, 4” of spring lift would usually cause vibrations. You may develop vibrations in the not-too-distant future once your U-joints suffer premature wear
Your 1" MML is why you're not getting vibrations with your 3.5" suspension lift. Since you're not getting vibrations I'd leave it as-is.I have 3.5 spring and a 1" body lift with a 1" MML. No spacers under the belly plate and have never had an issue. Was at least planning to replace the U joints while it's on the lift
Leave it alone.I have 3.5 spring and a 1" body lift with a 1" MML. No spacers under the belly plate and have never had an issue. Was at least planning to replace the U joints while it's on the lift
If you replace your driveshaft u-joints avoid store brands, I'd go with the Spicer 5-1310x u-joints which are a significantly stronger/more durable direct replacement for the base-level Spicer u-joints the factory installed. If you want to also replace the u-joints on the front axles I'd go for the Spicer 5-760x which is also a significantly stronger more durable direct replacement.
Also looking underneath, there is a dry oil patch on the floor board, looks like it was slinging oil from the T-case seal at one time.. Dirty but not wet, wonder if PO replaced the seal or if it's intermittent??
Freshly greased U-joints will sling grease like that, leaving a mess.
It's right above the T-case balancer...
LOL with questions like that, I hear a Tummy Tuck in your future :-D
