Recently noticed the TJ seemed to be squatting toward the right rear. Tonight I measured (no rear seat, no gear, totally unloaded in the back, sitting on level ground) and sure enough, the right rear shock is 1/2 inch or so shorter than the left rear. I haven't noticed any difference in ride. The lower shock mount is a touch wet, and the fluid isn't water, so I'm assuming I have a small seep/leak in the shop (no major signs running down the shock, but I did drive thru water recently, which could have washed any small/fresh signs off). The shocks have 20k miles on them and in any other vehicle, the shocks have lasted 80-100k miles and it was noticeable when they needed to be replaced.
- Does it sound like my shock is blown or on its way to being blown?
- Is this the normal amount of life I should expect on shocks for a TJ that's not abused, but is 'well used' (moderate to difficult trails)?
