T-Shirts
Order your offical Jeep Wrangler TJ Forum t-shirt today!
Click here to order!
Jeep Wrangler TJ Forum T-Shirts
Issue engaging 4 low
Breto31
Breto31
Kentucky
It’s the t-case drop causing the problem. That type of linkage can’t have much change to the pivot points. It’s just not designed for it.
Avoid 4LO until you get the cable shifter. If you need LO, reach under there and shift it by hand. Expect it to fall apart. Been there, done that. All those pieces will be hot as hell when you do it. Good times.
I can’t shift it by hand into 4LO because the the rod is hitting that piece, and won’t let it go into 4LO, so I can’t even use 4LO at all. Honestly, I won’t need it. I wheeled last weekend in 2WD and 4HI, and I don’t that much wheeling anyway. I just want it fixed in case I ever sell, or actually do need it.
AndyG
TJ Guru
Lifetime Supporting Member
Alabama
He's right, its cocked bad. They make a plate that helps, but the cable takes the entire assembly out of the picture and is independent of the body to transfer case relationship- it works flawlessly when it is set up correctly. Shift into 4wd with 1 finger.
Breto31
Breto31
Kentucky
I ordered the Savvy cable shifter this afternoon. Seems simple enough to install.
Huckster
Marietta, GA
Great info for my cable install. Mine shifts ok. Not great. You woulda thought Jeep could have done better job than the linkage conglomerate
Claybirdd
Alabama
As @AndyG Said to me one time, it's almost as if the engineers kept trying to make the linkage system better by adding bushings and tweaking the set-up rather than taking a step back and realizing the best course of action is to rip the whole system out and replace it with something better (cable shifter).
LONGJP2
Illinois
Everybody blames the linkage, expecting it to work flawlessly on a modified setup.
I used the AA adapter bracket to run the factory linkage for years without issue after my body lift.
I only switched to the cable to accommodate a TT. Plus I'm still having issues trying to get it set properly.
AndyG
TJ Guru
Alabama
They take a little patience to dial in - Blaine explained how to adjust it well in a recent post.
@Claybirdd had to fine tune his after I installed it and got it close - he is exceptionally capable.
pagrey
TJ Expert
Los Angeles, CA, USA
You could slightly bend the rod, grid the pivot, adjust the linkage the other direction or buy a cable shifter. Most people can't use a grinder or bend a steel rod so they spend the money.
Reactions: WestCoastDan
LONGJP2
Illinois
I've messed with it a few times, but not lately. It goes into 4L, but not enough to turn the light on. I'm assuming this also prevents the signal from allowing me to turn the lockers on. Fortunately, I have override switches, so it's not a big deal.
However, it has occasionally popped out of gear.
Seems like I've seen more issues with the 241 setup.
AndyG
TJ Guru
Alabama
My trick was to disconnect the cable , roll the actuator to 4 lo ( it will click in solidly) as a buddy holds the handle up- and then adjust the cable to to fit- that sets 4 lo with the handle up as the baseline. This worked perfect on my Rubicon. On Clays his still needed adjusted.
...it has to still be able to move the actuator all the way to 2 hi- The throw adjustment Blaine was talking about is key.
Reactions: JDM
