It needs nothing LJ
I wanted to mount my ipad (for mapping gia/onX) trail use above the radio/hvac vents. I don’t have a cage with the cross bar above the dash (yet) and I couldn’t find a suitable mounting point. I pulled the narrow dash section off (near the windshield) and found a couple studs with nuts that I assume are hold in the dash structure in place. These studs had enough threads exposed that I figured I could screw a “standoff” onto that would allow me to make a “mini cross bar”.
I machined a couple ½” OD aluminum pcs to a suitable length and drilled tapped them to fit the studs. I had to notch the dash plastic pcs to clear these studs (see pic).
I printed a couple end pcs that would fit over a ¾” bar and then screw into the standoffs. I notched the bar to allow the screws that screw into the standoff prevent the bar from rotating. I used an old 67 designs mounting bits to mount the ipad holder (I printed the holder as well) its plenty sturdy and doesn’t
bounce around.
ipad holder assembled.jpgipad holder end pc.jpgipad holder installed.jpgipad holder mounting studs.jpeg
Reactions: Unique Username
I bought this no name /no fit tailgate table off amazon for $40. https://www.amazon.com/dp/B0CFV3LKQ2?tag=wranglerorg-20 I figured for that price I wouldn’t feel too bad cutting it up and using the material for something else if it didn’t work out. I ended up trimming it a bit to get it to fit within the limited space of my fridge/tool box sleep platform. It had this weird pattern of holes / slots cut into it that sorta looked like a Chinese attempt at a jeep grill design. I found a way of covering that up so I have a solid surface. Was going to carbon fiber -but that was big $$ for a sheet large enough. Went to Home depot for inspiration and found that peel and stick vinyl sheet 12 x24 was just about perfect (cut it to 12 x 20) I then found a box of the stuff that was damaged so I got the entire box for $8. !
Used the provided nut serts to mount to tailgate -it actually works well and doesn’t rattle – for less than 50$ I’d say it’s a win
cutting trimming ghetto tailgate table.jpegghetto tailgate table folded.jpegghetto tailgate table modded for LJ.jpegghetto tailgate table open.jpeg
Reactions: Wildman
