Who has used this method for bumpstop on front spring perch? Is it reliable, does it make a difference if the vehicle will not be used offroad?
Drill a hole and tap it, then use a bolt.
X2. I tried a hockey puck held by JB Weld and it fell off within 1 or 2 trails.Drill a hole and tap it, then use a bolt.
... I decided to just reduce the amount of bump stop needed by bending my Currie track bar out ...
Would you explain this?
If I was any good at tapping threads, I would use that method. I have one shot and that's it I'm screwed if I mess it up. Only one of the perches can have a nut placed behind, the other has no access. Rubicon express makes a kit with self-tapping bolts, however I would still have to drill through inches of steel in an awkward place and the tapping could still go wrong.
I had read of some people using the hockey puck and JB weld method, but couldn't find much other information on it. One of the posts was of Jerry Bransford from 2008 and it fell out after trail riding.
I already have the springs out, it's a road only garage kept vehicle, so I decided to just reduce the amount of bump stop needed by bending my Currie track bar out. Not happy about having to modify a 466+ dollar bar that was supposed to be the best. But doing so should reduce my additional bump stop extension from 2.5 inches down to 1.625. With it being a road only vehicle driven once a week, I will just tolerate any potential rubbing on the bumpstop cup against the coil.
However this got me thinking that in the future for the next build I would have to come up with something better as it would be trail jeep. I guess I should have practiced tapping on scrap metal before I opened this can of worms.
Is it just the gusset at the frame end which hits? Many people have to grind that gusset out a little, and there are several threads on here mentioning it, but I can't find them at the moment. If it's the bar itself, then yeah, bending it should work. Do you have a press?
It's not hard to tap. I don't think I've ever messed one up, yet. Just go slow, make a few threads, back it out, go back in and go further, back it out, et. al., use a cutting oil. The perches aren't that thick, so it doesn't take too long. If you mess it up, go one size larger. Good practice.
A few taps can use common drill sizes, but most want a special drill bit. Get a tap drill size chart and find a common size really close (within a few thousandths of an inch diameter), or break down and go buy the exact size drill bit.
So I'm guessing this is where I was struggling, using regular common size drill bits and then using a tap, instead of a specific tap drill first. For example I drill out a 1/4 inch diameter hole, then proceed to use a 1/4-20 tap, when I needed a "#7" tap drill, right?
