Jeep dies immediately after starting
rossinator
Houston, TX
Hi,
I have a 2004 Jeep Wrangler 2.4L and it dies immediately after starting. There is no idle. Yesterday when I was messing around with it, i pushed the gas pedal and kept it at about 1500 rpms. After doing that for about 2 minutes, it began to idle ok and did not stall.
I replaced the TPS and cleaned the IAC. I have not thoroughly cleaned the throttle body. That is next on my list to do.
I have also listened for the fuel pump turning on after i turn the vehicle on. It turns on.
I have charged the battery. Any suggestions?
Any error codes? And yes, clean the throttle body to eliminate that.
Very important when u replaced the TPS and other sensors to only use an OEM.. not a store brand.
If u did get a store brand try to return it and get an OEM
Reactions: KCsTJ
Hi,
Though you say you charged the battery it still sounds like there's a marginal battery problem. The engine will not idle or idle for long with a dead or low battery.
