It seems to never end. I have had a slight pull to the left on the highway for a while. I was in need of an alignment. I completed the DIY alignment after installing new ball joints, hub kit and Currie steering. Still had same slight pull to the left at highway speeds. However now it has a pull to the right when letting off gas/ pushing in the clutch. I didn’t notice the developer pull in the first test drive, but after 20 miles or so it has started. Everything is tight/torqued. Air pressure may be a tad low, I will adjust when it cools back down. I did make some track bar adjustments and I am not sure if I resquared axles after or not, so I will check that. The tire shop put my newer spare on the right rear a while back, so being a tad bigger on one side could be causing some issues with the rubicon lsd in the rear. So I will reinstall my spare on the RR.
Anything else I should check?
