Jeep wanders
NEED HELP
co springs co
last summer i replaced upper and lower ball joints tie rod tie rod ends,pittman arm stabilizer shock and bar new 35 inch tires ,new steering box and the jeep still seems to wander and is dangerous to drive over 30 mph im confused about how to proceed from here
Dropped pitman arm? If so, remove it and go back to stock.
Reactions: Rickyd and JMT
X2^^^
If it’s not a dropped pitman arm, what’s your caster?
Mine did the same thing... turned out to be worn out track bar mount to frame and worn out sway bar links and x2 no dropped pitman arm
Have you checked the alignment? Are all the joints in the new suspension tight? Dry steering test? Also, is it a “new” steering box or is it a reman?
