Went to start the jeep this morning was idling rough then started to sound like it was gonna stall now won't start at all changed plugs and coil pack had new ones in the garage still nothing wants to start but won't
Try a little starting fluid in the throttle body & see if it'll start. If it will, that's a good sign the fuel pump is toast.
If you have fuel spraying from the injectors with spark, it will start. Did you measure the fuel pressure while the engine runs with the starting fluid? A bad fuel pump may be able to build up to 45-49 psi at first but not be able to sustain it once the engine starts or tries to start.Fuel pumps good 45 psi got spark still not starting
45-49 psi the entire starting cycle? If you do and it is truly getting spark, the engine will start. Spark gives a clear sign the engine computer is happy with all the inputs from the various sensors.Has fuel pressure trying to start
If a sensor was preventing the injectors from opening you wouldn't be getting spark. Are you truly getting spark?The injectors aren't opening to spray fuel in that's the problem a sensor is not letting it open what sensor I don't know
