Towing a trailer into remote areas, I don't really trust the range on my 06 TJ 4.0. I have a Wavian Jerry can which will add a bit over 5 gallons, but I'm trying to figure out where and how to mount it. Since custom building anything simply isn't happening, it looks like my two options for turnkey solutions are both from MORryde. Their side mount bracket and their spare mount bracket.
I'm probably going with the side mount since 5 gallons of gas isn't exactly light, and the can plus the gas in the can plus the spare seems like an awful lot of weight to put on the tailgate leveraged out that far. Nevertheless, MORryde seemed to think that something here should work. So I thought I'd ask--I've just upgraded to 31x10.5R15 tires which are about 6 lbs heavier than what I had (30x9.5R15). I have the factory steel wheels. I don't see the 31s and the steel wheels changing anytime. I've seen discussion from people with 33s or 35s, but I'm going to stick with scrawny 31s.
MORryde sells heavier duty tailgate hinges, and/or some kind of reinforced frame for the tailgate. Under what conditions would adding the tire mount jerry can make reasonable sense with 31in tires? Just the hinges? Both? Never?
I should add that I am not wheeling hardcore stuff (I couldn't with 31s and no lift.) My offroad use is more of the "overland" variety, especially if I'm towing a 1600lb trailer.
Like I said, I'm 90% probability going for a side mount, but I still prefer something in the rear if my weight fears are alleviated.
