JL Xtreme Recon wheels on an LJ?
Roughly 5-1/8”
So that makes more sense based on the +12mm for an 8" wheel. Not sure why the website lists it as 4.4" of backspace.
Especially since that is from the MOPAR website I took the screenshot. Maybe they are measuring from the flange to the bead seat?
@cfree , do you have the lock rings, or are you just going to stick with the beauty rings? I like the look of them, I was going to go with these for my Gladiator (they look almost identical to the stock Overland wheels), but it was a hard spend...
I’m using the beauty rings
Reactions: Artsifrtsi
So is the consensus 1.25” adapters? 1.5”? Does it really matter? 😅
I run a 1.5" adapter up front and a 1.25" in the rear. Mine is split due to the SwayLoc. The 1.25" adapter results in the tires getting into the SawLoc arms. Even with the 1.5" adapter, I'm still into the arms very slightly.
In your case, the 1.25' adapter will work perfectly, assuming you don't have a SwayLoc, and net you approximately a 3 7/8" BS.
That said, anyone looking at these wheels, don't buy them because they're beadlock capable. The combined cost of the wheels, adapters, and beadlock rings, if you can find them, is approaching forged beadlocks. In my case, I bought them because they're my favorite wheel, factory or aftermarket, they look right at home on the LJ, and I got a very, very good deal.
Lastly, if you run these, go with a slightly larger base 21mm 1/2x20 lug nuts, Like these:
https://www.amazon.com/gp/product/B07QM9WD6B/?tag=wranglerorg-20
Here's mine with 35" KO2s:
Hmmm I was considering the Antirock sway bars… Good to consider. Thanks!
Love that green, btw! Those wheels are perfect.
Do you not run with a spare tire?
I'm having trouble getting the JL wheels to fit on the tailgate. I tried the Spartacus tire carrier, but it is way too far away from the tailgate because it requires an adapter to fit the JL wheel. I then tried the Rugged Ridge adapter, and using the 5x5 pattern, it places the tire ON the tire carrier, so that's no good. Kind of at a loss and wondering if the JL wheels are worth it.
Reactions: Irun
Reactions: cfree
Ah, you have a different bumper. Without an extension the tire gets hung up on stock bumper. I was able to get it to work with the Teraflex bracket, wheel adapter and the stock carrier, but it sticks out from the tailgate a fair amount.
The hang up on the bumper went away on mine with the 1.25 body lift..
