What grease are you using and when disassembled are there deposits on the ball and bushings?
I’ve never disassembled mine, so I have no actual idea. I hit the zerks with Red and Tacky every so often (yes, I know…), and they remain quite as mouse.
You didn't ask me, but
Yes....Lucas red n tacky
Yes....CV2
I cleaned the balls up with emery cloth, smooth to the touch but you can still see theyre rough, replace em or run em?
my rear UCA's were really creaking when I was cycling things as I replaced my rear springs this weekend. I pulled one off and this is what the Johnny Joints look like. These had been previous lubricated with Energy Suspension formula 5 prelube.
The balls and the races mostly feel dry. Where there is accumulation of grease on the outer edges where there's not tight, preload contact, it's REALLY tacky, and feels more like an adhesive than a lubricant. Now I'm researching chemical compatibility to try to find a solvent that will remove the silicone grease without damaging the polyurethane...Thinking I may try gasoline.
Edit: mineral spirits did the trick but based on the fact that mineral spirits are used as a thinner for polyurethane paint, I think long term exposure would not be good. So I just wiped them with a soaked paper towel and quickly put them in a dish soap bath.
The whole thing gives me a bit of pause about using any more silicone based grease on these, but I'm stuck for a couple of days if I wait because I happen to be out of CV2 and its not available locally.
Any petroleum product will eventually dissolve plastic, since they are both made from petroleum. I used brake cleaner, diesel, kerosene, etc to clean mine. Whatever is handy. The liquids are much more volatile than the solids, so you really don’t have much to worry about
Did you have the same experience with silicone turning gummy and disappearing almost entirely from the bearing surfaces? At least the Cv2 still left stuff a somewhat greasy/oily feeling when I took the joint apart, even if it was creaking at the time.
Yeah, but I didn’t find that unusual, since I’ve had the same experience with CV2
I can't remember, why is the Moly grease that Rock Jock sells not used?
I'm guilty of not using it either. When I got my Savvy arms, I pulled all the joints to make sure they were greased after reading on here about some getting them with little to no grease. As it turned out two or three of mine had little to no grease as well. I used Cv2 on all of them except the two front upper axle joints. I meant to check them and use Cv2 but those went on at a later time and I forgot and just never got around to doing it.
I hope you all figure this out soon before I get this midarm on! Then I can also lube up the savvy arms when the new owner takes them.
I'm still holding out hope that I can get the hole lined up with the zerk
In your environment, just use the Cv2
I have some too, but I’ve been too lazy to try and squirt some in. Mine aren’t making noise…but I’ll get around to it. It’s about time for my annual maintenance anyway
