Back to the TC, I’m still formulating my plan of attack. I know I want an Atlas, mostly because I have a lead foot & it seems to be very versatile but also strong enough that if I get bigger axles in the future then it won’t need to be replaced. My goal is to build the TJ up so I can tow it all over the country to traverse the different landscapes & take the kids camping. Currently I have 31s on the stock 30/35 setup w/ 3.07 gears. I’d like to keep the 30/35 setup but with upgraded components & reinforcements to run 33s. at least until I get the funds to play with the big boys.
Getting compatible components & the order I should install them in is where things start to get a but confusing.
For TC configuration is bigger always better? Meaning, if I get the lowest gear ratio, CV yoke, HD tail housing, etc. will this require completely replacing the axles or can I get away with stronger components?
Also, If I plan to re-gear, will I also need to replace the yoke or diff cover?
Upgrading the axles is something I’m aware of, but what will I need to make these changes?
Are bigger brakes a must have with a stronger TC & lower gear ratio?
If so, will larger calipers be enough or do I need a larger diameter rotor as well?
Can all this be done w/o doing the lift right now?
I’m not trying to cheap out or avoid extra work, I just don’t know what I don’t know. I’m diligently scanning this forum for knowledge so I don’t end up wasting time & money
