Hey Guys,
So I recently bought a 2004 rubicon with a 5 speed. It has 33" tires so I decided to have it re-geared with 4.88's. Picked it up after work and drove it home. About 30 minute drive. When I got close to home, going around a corner I heard the rear end "pop". Drove around to try and reproduce problem. I was in a parking lot doing figure eights at a low speed. It popped 2 more times while turning right. I was going super slow at one point and the rear driver tire started to "slip". Lost traction on asphalt for a second.
Of course the shop was closed when I called to report issue. What could cause this? Back in the early 2000's I had a 91 YJ and I destroyed the spider gears in the rear. That made a similar "pop" to what I'm experiencing on my rubicon. But, with the YJ it made the noise every time I made a right turn and it sounded a lot worse. Any insight would be appreciated. Thanks.
