I have a 6 cyl 1998 Jeep Wrangler. I cranked it in the morning and as usual it never fires on first key turn but always on 2nd. So turned key back to off then back on to crank again - absolutely nothing - no crank at all.All dash lights are normally. Battery is good, I replaced the ignition switch block on LHS of column (fiddly little thing but got it done and have the "normal" springy key feeling) but still - no crank at all. What is the likely issue here? Is it a bad starter? I mean vehicle never moved before key turn 1 and key turn 2 so I doubt a connection failed and when I look at starter I see the cable connected tightly..
