Hello all,
That title wasn't phrased very well, but in essence I'm trying to figure out what part(s) I need to replace for my leaking transmission oil system. The leak is happening right at the side of the oil tank below the radiator. This is the only picture I have on hand right now:
It's the passenger side tube on the tank directly underneath the radiator. The leak is happening right at the silver washer looking part.
I should note that I'm mostly sure that it's transmission oil, but it very well could be the antifreeze/engine coolant. But from all the diagrams I've seen this tube is the transmission oil line though.
I'm wondering if this is something I can replace easily or if there it's going to be a bigger job (like replacing he radiator itself) I'd be happy to answer any questions you might have. Any help would be much appreciated!
