LED tail light install issues
coloradomtn
Colorado
Hi, I recently replaced my 03 taillights with LEDs. This is the product I installed.
Quadratec LED Tail Light Kit for 01-06 Jeep Wrangler TJ & Unlimited
During the installation, everything tested fine but I forgot to test the lights with the headlights on. When the headlights are turned on, the driver's side rear works fine but the passenger side doesn't. When the headlights are turned off, everything works perfectly. Any ideas on where I might have gotten the wiring wrong?
Did you install the LED flasher relay to go with them?
Yes, we installed the flasher. The indicator and reverse lights on both sides work great. The only light that doesn't work is the passenger tail light when the headlights are turned on.
Sounds like a ground issue. The taillight circuit grounds to the body, so make sure the connections are clean where it mounts to the body.
Reactions: K0LCB
