Hello All,
I am having an issue where my left blinker will come on solid when when the brake is pressed. I originally had a similar problem with my windshield wipers and left blinker turning on when the brake is pressed. Turned out to be a bad ground on the driver side headlight. I have triple checked the grounds that i know of and all are good. Considering changing out the actual blinker lever on the column but wanted to see if anyone else has had a the same thing. Also, when it comes on solid I can jiggle the blinker lever and it will go away until I press the brake again. Which is why I am thinking its the lever on the column. Thanks in advance for every ones inputs. I have gone through old post before to solve other things and this forum has been very helpful.
