Looking for a video on how to remove the rear axle
He just broke his Dana 35 so I'm going to assume axle shaft.
to remove a Dana 35 axle shaft, take the diff cover off (drain bucket under the pumpkin to catch the fluid running out), pull out the cross pin bolt (I believe it is 1/4" 12 point head), remove the cross pin, push the axle shaft inward so the c-clip falls out, then pull the shaft out.
So you blew the Dana 35 and not the T case? Yeppers, exactly what Macho said. easy doins, just messy. Macho can do with blind fold on Id bet. ;) If you broke a axle made uber sure you get ALL the metal fragemnts out or you can kiss the bearings and gears adaios.
Dana 44 or 35 ?
spoke to who I bought it from he said dana 35 found a video to make easier but there is a locker no clue how to get apart or what kind
I need to find all the broken pieces of the axel shaft so I need to get complete apart and inspect for damage
stamped 105020 Dana 35-456 dana 35 with 4.56 gears
I think I found it
POWERTRAX GRIP PRO TRACTION SYSTEM, 27 SPLINE - DANA 35​
but need how the hell get it out
  • IMG_3738.HEIC
  • IMG_3739.HEIC
  • IMG_3740.HEIC
  • IMG_3741.HEIC
