I’m in need of a new or a rebuilt throttle body. Anyone have a good source. Ive been chasing a damn vacuum leak and finally said screw it and have just replaced everything I could think of. And it’s gotten better but still not fixed to my liking. It is sporadic, some days it will idle fine others it’s 1500. And the vents don’t work right and it blows from only defrost. So I know it’s a vacuum issue. I have smoke tested it multiple times without ever finding but two leaks. One was fixed in the AC harness but I the replaced with new factory lines the other was the TB throttle linkage. I have replaced every vacuum line in the engine bay, the vacuum box under the battery, the A/C vacuum switch and hoses, the brake booster hose, the canister purge harness lines, the PCV elbow and lines and rubber ends. I’ve replaced the the intake and exhaust gasket, and smoke tested it again and smoke is now pushing out of the throttle linkage shaft. Were before it was coming out of the A/C line by the firewall also. Even though I got it patched with rubber hose and it no longer smoked I was still having issues with high and irrational idle. I have cleaned the IAC and housing, it’s got a six month old Mopar TPS in it already, so I’m now going to swap the TB. Any place to look for a good TB
