Thanks! A lot of info is correct, this will give me some comparisons to help in the decisionThis thread should answer most if not all of your questions.
https://wranglertjforum.com/threads/rock-sliders-rocker-guards-guide.8704/
Not sure of the brand! Most of the aftermarket items on the Jeep were barricades! They are a light weight Nerf Bar! They lookWhich brand did you bend?
Mopar made one, but I don't know if any are still available.
https://wranglertjforum.com/threads/oe-mopar-rock-rails-fits-04-06-lj-brand-new-in-box.13670/
Thanks Jerry! Those do look super strong! Like the idea of that inter sandwich piece (other than pulling the interior out )Check out Savvy's 3-piece rocker guards designed by mrblaine. The base is 2 pieces of heavy aluminum that sandwich the tub and the 3rd is the heavy steel outer guard. It holds up to major impacts like my TJ has seen a lot of. I bent my previous rocker guards.
These photos show my previous TJ, I'm running these on my present TJ too.
View attachment 153864View attachment 153865View attachment 153866View attachment 153867View attachment 153868
Question- LoD show a frame mount system instead of a rocker sandwich- your or anyone else’s thoughts on a frame mount
Frame mounting may sound stronger but it's not even close to being as strong as tub mounted which also provide more ground clearance with nothing to get hung up on.Thanks Jerry! Those do look super strong! Like the idea of that inter sandwich piece (other than pulling the interior out )
Question for you- some of the guards promote the 45 degree angle to help slide off a hazard and not get hung up ! Your feelings on this- Thanks again- I’ve always value your opinions because I guess you’ve been there-done that and are always here to help! Ok enough bull, Let’s Ride!
Jerry I just checked out the Savvy site, your pics are better! Question- LoD show a frame mount system instead of a rocker sandwich- your or anyone else’s thoughts on a frame mount
I figured you would say that! Thanks again! I’ll have to ask the wife if I can get into her purse and just get a little more money!Frame mounting may sound stronger but it's not even close to being as strong as tub mounted which also provide more ground clearance with nothing to get hung up on.
