Looks like Metalcloak is trying to out-do OR-Fab with their tire carrier
https://metalcloak.com/jeep-tj-lj-tub-mount-spare-tire-carrier.html
ay looks nice and sturdy when it's pegged at 4 points on soft bushings, i don't doubt it could handle a 40 and i bet it's great as far as rattle. but not 1x does it show it actually close, most of that is animated.
my point is more if 2 of those bushings can't hold a 35 dead nuts level and not allow as much as 1/8" sag when loosed of those brackets no way it's good enough to be running on a TB. more what i was thinkin.
i can see it drop out of the bracket when opened and when it contacts the bracket when closing even though they blocked that part from view.
I dunno, I watched it. They show the carrier coming closed at about the 2:20 mark. Looks like it slides right home. Its overbuilt, imho. 7 gage steel is what? 1/4" thick? 3/16 wall tubing? That's gonna add another 100+ lbs on the back of your jeep, BEFORE you ever put a tire or a tank of water, fuel, hi-lift, whatever on.ay looks nice and sturdy when it's pegged at 4 points on soft bushings, i don't doubt it could handle a 40 and i bet it's great as far as rattle. but not 1x does it show it actually close, most of that is animated.
my point is more if 2 of those bushings can't hold a 35 dead nuts level and not allow as much as 1/8" sag when loosed of those brackets no way it's good enough to be running on a TB. more what i was thinkin. this is a great application for those bushings........not the TB.
What the heck is TB connection?220 and view of contact is blocked.
nothing about how it's built, it's fine and i think this is a much better application for those bushings.
the tabs on the release side are bent for a reason.
1 more time that thing is fine .......a bit expensive and probably heavy, but would function as advertised.
but if that bushing flexes 1mm under weight of a tire, how well can it really control your rig at TB connection, is my thought.
Better than their Duroflex bushing can...., how well can it really control your rig at TB connection, is my thought.
if the 2 joints are the same materials it all comes full circle to does it have a high enough durometer rating for link control. i can't point to any direct issue but the soft material leaves questions.Better than their Duroflex bushing can.
I can complain about Metalcloak all day long, but I never had any problems with the Durotrak bushing in the front track bar. But like anything else surrounding Metalcloak marketing hype, their magic bushing doesn't do anything in that application that a cheap rubber cleavite can't do just as well.
