Losing power and jerking while accelerating
No, it’s still really intermittent and hasn’t occurred now in weeks. I did pull the fuel rail and install some heat shielding. I had a TPS on order that Amazon nicely cancelled for me based on lack of availability.
I might have fixed mine today, I disassembled the throttle body and cleaned it really well. I also realized the plastic holding clip for one of the sensors had broken, resulting in a loose connection. Once I fixed both, it hasn't happened again since. Here's to hoping it's fixed!
Reactions: JeepZilla380
So super random but i had the same problem... changed everything still didnt fix it and then my kid found waaay deep in a forum that the #3 and #4 injector wires could have been crossed at the factory, another guy took the wire loom off and the 2 wires that looked the same length 1 of them had extra wire inside the loom and was actually longer....
Reactions: Blondie70
Just in case, this was solved in 6 episodes starting from this one:
Ending with this one:
The problem they found was also found on 3 more Jeep's, and it is
low pressure fuel pipe filer mailfunction
Oh, and just in case, - they are Russians, not ruZZians - you can tell it by the amount of blue and yellow in their videos. That's very much only option to tell a position in Russia nowadays - everything else will lead to 10y/death in jail.
