When I cold start my tj it beeps and the check gauges light comes on. I took it in to a jeep shop to diagnose some other issues and was told that it is because my oil pressure is low. The gauge on the dash is slow to increase from a cold start. But as the car idles it always sits around 40psi. However at the shop, I was told even though The gauge said 40psi, the computer was reading around 10psi. He told me to change out the oil pressure sender. So I did. Now, I get the beep and check gauges light about half the time I cold start.
I’m not sure where to start diagnosing. Also, would low oil pressure explain why she doesn’t want to cold start on the first crank? Fuel filter, spark plugs, fuel injectors, and vacuum lines have been replaced. And after I changed each of those it would start right up for a week or so and then be back to not wanting to start again
