I built this maintenance tracker off the 2006 Schedule B to help keep track of everything. If you are new like I am and are curious if you use Schedule A or B it basically boils down to this question:
Do you plan on driving anywhere on planet Earth? —> Yes. Use schedule B
Figured I'd attach it for others to use. Takes a little to set up but once you do just simply update the miles from the odometer. If you want to change the mileage interval just update the formula in column C. Also curious others feedback on what to add to this to track as well.
