This ones a head-scratcher for me but hopefully someone can help. Im trying to understand how to interpret MAP (inHG) readings on my scanner.
Context is this:
according to FSM, one of the conditions required for the Jeep to run the EVA drive cycle is to have MAP(inHg) of 22 or higher. So….
Q1: is that with engine off, at idle, or driving?
Q2: If my scanner shows a value below 22, then how can I diagnose the cause? Seems to me that the cause could be anywhere within the EVAP system as a whole or it could be the actual MAP sensor itself…right?
My first instinct is to replace the sensor but that seems futile if the sensor isnt the problem. I’m not getting any codes but I do have the flashing EVA alert, and havent been able to complete the drive cycle despite going through several tanks of gas and attempting the “idle five min the drive 35-40 for ten min” condtions at least 10 times now.
Context is this:
