Does anyone know what a "sane" low PSI value would be for 35x12.50 (BFG KO2s) on 15x10 non-beadlock aluminum wheels?
What's the width of the tire and the width of the wheel?Does anyone know what a "sane" low PSI value would be for 35" (BFG KO2s) on 15" non-beadlock aluminum wheels?
Ahh my bad, 12.5" wide tires and I'm pretty sure the wheel is 15x12.What's the width of the tire and the width of the wheel?
Hopefully the wheel is nowhere near 12" wide. 8" is optimal, even 10" wide is a little too wide for airing tires down much.Ahh my bad, 12.5" wide tires and I'm pretty sure the wheel is 15x12.
Freudian slip. 15x10 is what I meant.So I'm going to pretend the wheel is 8-10 inches because I'm thinking that is going to be what it ends up being.
Question: what kind of terrain are you airing down for? That might help people understand the degree of airing down that makes sense.
My gut says don't go under 12 but that's a total guess and that would be something I would do for low speed crawling. For higher speed stuff maybe 15? Again, these are what I would try that would be reasonably safe. I always leave my spare at 25 though so I can match lower psi if I need to.
Oh good, I was thinking it must be a typo. Sorry I can't give you solid numbers because I only run 33s at the moment so I hope they aren't too different, I just saw that your thread wasn't getting any traction so I thought I might be able to get things started.Freudian slip. 15x10 is what I meant.
I don't do any super hardcore wheeling (no daredevil Moab type stuff, just shady mountain trails and washed out creeks for the most part). I haven't dropped the PSI below 26.5 (cold), but as the tread wears I'd like to get them down a little further. Based off of what you wrote, my next target of 22 PSI should be fine then.
.... I’ve read people running those to 8 without losing a bead, but haven’t tried that.
Sent from my iPhone using Tapatalk Pro
15x10. I had the number 12 on my mind late last night when I replied.Wait... your wheels are 15x12 @jeep_boss? DAMN that's wide!
My technical English is not perfect, but think you mean humps with it.Does anyone know what a "sane" low PSI value would be for 35x12.50 (BFG KO2s) on 15x10 non-beadlock aluminum wheels?
