I am still chasing some electrical problems with my jeep. Saw check engine light starting to blink engine started running rough pulled over and died. Jeep would not even crank dash lights would come but needles didnt move. Next morning saw a problem with the ignition coil (crack and melted plastic). No problem changed coil and plugs everything back together and same thing, no crank and needles didnt move. Plugged my OBII reader in and it wouldnt even connect to the PCM. I replaced my PCM in OCT 2018 and ran fine for over 40k. I still have the old PCM and installed the old one and nothing no crank and no needle movement.
I cant say its the PCM since with both my engine is doing the same. It has to be electrical but where? I am going to go over the main electrical harness this weekend to see if any wires are broken. Any hints out there?
I always wanted a Jeep and got the model and engine I wanted but everything thats given me hell has been electrical. I have replaced the radiator , water pump , thermostat, PCM, front pads, rear parking brake shoes, ignition coil and plugs. transmission rebuilt in 2021. Probably needs rear bears and u joints.
So any help will be appreciated.
