Fluid Film is almost ideal for your purposes. It can get into areas that paint can't. And it is removable with little work. And it coats and protects through the rust keeping the rust from getting worse. In the Spring you can wash it off and get at the rust in warmer weather. A good coating underneath getting inside the frame and torque box will keep the corrosion at bay.
Por15 is a good product, but 100% prep work is needed to stop rust underneath it. And cold weather makes the prep work difficult without a heated shop for the chemicals to be effective.
FF is lanolin based. The stuff that keeps all those sheep warm and dry in the wet and cold weather. Plus if you get any on you just rub it in to help with your chapped and dry skin!
