So, let me start by telling you what I have. I have an 05 Rubi 6spd that's lifted 3" front, 2.25" rear. I have a high clearance Rough Country skid plate that I currently have lowered 2", which makes the transmission sit at the same height as it did with the factory skid plate. I have no driveline vibs as it sits now.
I want to get and install a 1" BL and 1" MML. My reason for this is to try and get the skid plate raised up some. Since the MML is usually used to cure driveline vibs, I'm thinking that installing one "should" allow me to raise the skid up. Maybe not the full 2", but some.
Is there any sort of formula for how much lift an MML takes care of? Since I have no vibs as is, how much higher would you guess that I'd be able to raise the skid? I know this will probably be a trial and error kind of thing (which is fine), but I want to get a rough idea in my head.
I should also mention that I do not have adjustable rear control arms.
