I'm definitely NOT (edited for omission) trying to out engineer them or have any illusions that I'm going to improve on what they did, I just want to make sure what I have is operating as they intended it. I do apply some skepticism to gauge readings when I know they've been manipulated to reduce dealer warranty calls and it's guaranteed that a compromise was made in a boardroom when they decided how much to compress the reading into that central quarter inch of temperature gauge and at what temperature it should jump to the red.
In 2018 I replaced an aftermarket radiator because I hit 235 on the interstate (via scanner with needle covering right side of the zero). With the Mopar radiator the only time it ever even thought about crossing 210 (via scanner) was when I went from working it hard on the highway to a sudden stop and extended idle in traffic and it got to 215-217. That "experience" reinforced the idea that below 210 (the actual number, not the vague area on a gauge) was etched in stone and exceeding it with any regularity means something is wrong. Now I have an LJ with a mopar radiator that reaches close to 230, almost to the same range that the TJ did with the aftermarket radiator in similar conditions. It's only a needle-width or two past the 210 hash mark, so if I brought my LJ to you and said I think it's running warm, would you look into it or send me on my way and tell me to save my money for something else?
