So large amount of stuff done this past weekend, belt, pully and tensioner (cause of all the noise under the hood), oil and filter, new plugs and coil, cleaned seat, new Quadratec LED headlights (originals both were toast...one didn't work the other the seal was broken between glass and housing).
Have tons more soon, 4 hole injectors, B&M shifter and Savvy Transfer case cable....all parts are in the garage ready to install.
So here comes the dumb question. This is a 2003 X model with manual trans....should know that from above but for completenes sake. The HVAC does not switch from vents.....at least it is on vent...can stay warm. I know it is either a vacuum line or the lever for the flap....but I am not sure where to start with looking on the vacuum lines....just looking for some of the usualy supects on the vacuum lines that need replacing....quick glance does not show me any areas that look bad.
Let me know where you have found bad vacuum lines or where to start.
Thank you
Thank you
