Good Evening All,
Alright, did ZJ steering conversion Thursday, all went well, installed Tie Rod BAR, Drag Link Bar, tie rod ends on both, removed drop pitman arm and installed stock one. Installed new tires, 33x12.5x15 BF Goodrich K02 A/T, wheels were balanced, old tires were some junk mud tires. Jeep rides quieter and smoother, but still steers on its own (but it still needs an alignment). Originally after installing the new steering, the Jeep wasn't driveable, because of the alignment, did a quick (did not measure) alignment in driveway, and got it driveable now. Can't seem to find a decent shop near me that does alignments on 4x4, and the ones that do are giving me appointments so far out. So I will attempt a driveway alignment with measuring tapes and what not. It still steers more to the left than to the right, when hitting bumps you really feel it and shakes, but it doesn't persist, goes away right after hitting bump. Steering is like I said all over the place but mainly to the left. I know I will need a a trackbar, I am wondering should I just get the Moog stock track bar, or an adjustable? If adjustable, anyone have any recommendations? But any recommendations on how to really get this steering fixed? Is this really only because of an alignment?
01' Jeep Sport, 4.0 5SPD MT, has a 3 inch lift (no idea what brand, PO installed) ZJ steering, new ball joints and lower control arms (will be installing new upper arms).
Thanks in advance.
EDIT: Also a new noise has started after tires were put on. When I am in a gear (any gear) and I let go of the gas pedal to say slow down, I hear a noise from the rear, but if I put it in neutral and let the car roll and slow down, no noise. Any ideas? I'm not sure how to describe the noise, maybe a low-pitched whine? definitely coming from the rear, and only when in a gear and no gas being applied. Sorry I suck at explaining in writing.... lol
Thanks in advance.
