My AxX5 trans is showing signs of some potential syncro issues. I am contemplating an AX15 swap into my 2.5. The AX15 is about 2” longer than the ax5. I don’t have the room for a shorter driveshaft due to running a doubler setup. So that leaves the option of moving the engine forward.
I do not want to cut and weld frame mounts. I thought of custom block brackets, not sure how well they will hold up. I was thinking since I am running a MML what if I used the same thickness aluminum, bolted it to the stock location then drilled new holes 2” forward in the aluminum block for the motor mount? Obviously with new custom MMl blocks?
What do you all think is the best route to accomplish this?
